how to check for a string in SELECT command
Sean87
Hi all,
I am trying to simulate a program, but it always pop ups for a syntax error in the following line :
        case ("restart")
	        sertxd("Reseting the program!")
	        b1 = 0
How to write case ("restart") ?
this is the full program if it helps answering:
main: 'main program entry
    low 0,1,2,3,4,5,6,7 'set all outputs to low
    serrxd ("go") 'wait to receive string "go" from serial port
    reconnect 'reconnects after receiving "go"from serial port
    goto _read 'Goes to _read sub
_read:
        serrxd b0 'waits to receive a string from serial port
    select b0
        case "0"
      	  sertxd("LED 0 Toggled!")
        	toggle 0
        case "1"
      	  sertxd("LED 1 Toggled!")
        	toggle 1
        case "2"
     	   sertxd("LED 2 Toggled!")
        	toggle 2
        case "3"
     	   sertxd("LED 3 Toggled!")
        	toggle 3
        case "4"
       	 sertxd("LED 4 Toggled!")
        	toggle 4
        case "5"
        	sertxd("LED 5 Toggled!")
        	toggle 5
        case "6"
	     	sertxd("Dancing!")
        	goto dance
        case ("restart")
	        b1 = 0
        	goto _read
    endselect
    goto _read
dance:
high 0,2,4
pause 50
low 0,2,4
pause 50
high 1,3,5
pause 50
low 1,3,5
high 0,2,4
pause 100
low 0,2,4
pause 100
high 1,3,5
pause 100
low 1,3,5
high 0,2,4
pause 200
low 0,2,4
pause 200
high 1,3,5
pause 200
low 1,3,5
goto _read
MartinM57
No correction, but apart from fixed strings in sertxd-type statements only single characters can be held in variables and tested against
e.g.
b1 = "A"
if B1 = "A" then ...
papaof2
So is there a workaround to do some stuff based on strings received?
As Martin said, you can test SINGLE characters. There are NO string variables. It's part of of the design.
There is NO capability for
IF StringVariable = "SomeValue" then
do_whatever
END IF
The only workaround is to receive a string into multiple byte variables and test each byte in turn to determine what the sequence of characters is. That's inherently slow and complex.
John
ckoehn
Indeed it is like John said. You would need something like this..
#picaxe 20x2
eeprom 0,("restart","start")
	ptr=0	'set scratchpad location
nextbyte:
	'read till 13 is received
	serrxd b0	'wait for char, then inc pointer
	reconnect
	@ptrinc=b0
	if b0=13 then
		'================ check if strings match =======================
		b1=0	'"restart" eeprom position
		b2=7	'7 char to match
		gosub checkmatch
		if b1=255 then
			'matches "restart"
			'do something
		b1=7	'"start" eeprom position
		b2=5	'5 char to match
		gosub checkmatch
		if b1=255 then
			'matches "start"
			'do something
		goto main	'do again
	goto nextbyte
checkmatch:
	ptr=4
	b3=b1
	for b0=1 to b2
		read b3,b1
		if b1<>@ptr then
			'not a match
			b1=0
		inc b3	'get next location to compare
		inc ptr
	next
	b1=255	'made it all the way through
Later,
Clint
