how to change GPS characters into numbers
mary rose
I want to change the hour time from a GPS module which is in separate characters into a number. For example 12 o'clock is an ascii character for '1' followed by an ascii character for '2'. I want to change the 2 characters and merge into 1 variable number '12' so I can simply then add or subtract to display different time zones.
setfreq m16
serin c.4,T9600_16,("GGA"),b27,b0,b1,b2,b3,b4,b5
setfreq m4
serout c.1,N2400, (254,128,"UTC ",b0,b1,":",b2,b3,":",b4,b5," ")
AllyCat
There have been previous posts on the forum concerning the parsing of GPS strings, so a search for "GPS" or "parse" might be productive, but....
The mathematical principle behind a number like "123" is that it represents a number formed of (1 * 100) + (2 * 10) + 3 . So you can convert the digit sequence b0 , b1 to a "real" number by using value = b0 * 10 + b1 , etc.
But first you need to convert each ASCII value into a digit. That can be done by subtracting 48 (because the ASCII value for zero is 48) , but this can be written more clearly by directly subtracting "0". Thus you can do your hours conversion with a single line such as hour = b0 - "0" * 10 + b1 - "0". For example, here's the test code that I tried in the simulator to check that I wasn't t misleading you :
symbol hour = w5
b0 = "2"
b1 = "3"
sertxd(#hour)
That can be extended further but there are several potential "gotcha"s: You must remember that PICaxe maths always works strictly from left to right and also, not all GPS ASCII strings are parsed with a fixed (or constant) number of characters (so your program might need to scan for a ":" or "." character first).
mary rose
symbol hour = w5
b0 = "2"
b1 = "3"
sertxd(#hour)
Thanks Alan. You've put me on the right track.
Cheers
Bob, ZL4CE
Untested (by me) for your GPS application however, try using the hash ( # ) symbol in front of your variable in the SERIN command.
so instead of
SERIN pin, baud (“GGA”), b27, b1, b2, b3, b4, b5
Where/if you are expecting say
B1 = “1”
B2 = “2”
B3 = “:”
B4 = “3” and
B5 = “5”
try
SERIN pin, baud, (“GGA”), b27, #b1,#b2
B1 should receive the “1” and “2” and contain 12 terminated by the “:” (a none numeric character)
Then B2 would contain the minutes,
subject to the minutes characters being followed by a non digit (0-9) character.
however if your time string does not have separators between the hours, minutes and seconds then this will not work.
marks
Hi mary rose,
you may be interested at this code snippet
just updated to work with a neo gps will rewrite post#1 when I get a chance
mary rose
thanks everyone, success! Exactly what I wanted
symbol hours = b6
symbol mins = b7
symbol secs = b8
serout c.1,n2400,(254,1)
setfreq m16
hours = b0 - "0" * 10 + b1 - "0"
mins = b2 - "0" * 10 + b3 - "0"
secs = b4 - "0" * 10 + b5 - "0"
debug
setfreq m4
serout c.1,N2400, (254,128," UTC ",#hours,":",#mins,":",#secs)
There is some mathematical trickery which can be used to improve that. Putting brackets around things to reflect real world maths rather than PICAXE maths ...
hours = ( ( b0 - "0" ) * 10 ) + b1 - "0"
hours = ( b0 * 10 ) - ( "0" * 10 ) + b1 - "0"
hours = ( b0 * 10 ) + b1 - "0" - ( "0" * 10 )
hours = ( b0 * 10 ) + b1 - ( "0" * 11 )
hours = ( b0 * 10 ) + b1 - ( 48 * 11 )
hours = ( b0 * 10 ) + b1 - 528
And that handily suits PICAXE left to right maths. The PICAXE supports 16-bit maths so there is no overflow, the result will be correct when the 'hour' byte value is set ...
hours = b0 * 10 + b1 - 528
mins = b2 * 10 + b3 - 528
secs = b4 * 10 + b5 - 528
b0 = "2" : b1 = "3"
b2 = b0 * 10 + b1 - 528
SerTxd( b0, b1, " = ", #b2, CR, LF )
