Do you mean the program is running and you cant stop it?
Disconnect the power, start a download using the Programming Editor, then reconnect the power when the box appears on screen. Try it several times if it doesn't work at first (though it should so long as you wait long enough for the box to appear). This is known as a "Hard Reset".
