Okay, that the the Rev Ed AXE020 proto-board.http://letsmakerobots.com/node/75
Darn! my crystal ball is on the blink again.That's how I connected the sensor... .
an area to the right of the digital inputs is circled in light green. But I see no indication of actual connections.The IR-area
This is a quite undocumented feature on the board! It is used if you want to use standard TV-remote control-protocols to send to your microcontroller.
You can hook up IR ins-and out to anything, to measure IR, for instance to see if something is near or far, or white or black.. but you will have to do with analouge levels of signal and similar, you will not be able to transmit "signals" that can be translated to numbers such as TV romotes does. Most IR remote controls use 38 KHz sub-carrier, and this area let´s you hook up to that quite simply. You should only use it for that!
This means the output voltage will vary between 0 and 5 volts, this will depend on the distance to the object it is detecting.Provides an analog voltage
It says that on the website... I don't know what that means....
No that means the sensor output voltage wont go over 2.4 volts, the supply voltage to the sensor is 5 volts.So is that means my voltage cannot over 2.4 volt ?
Well normally it is, but what are you asking about, the ground wire to what?Ground wire always is the black one right?
