HIGH and LOW 18 and 40x2 chips
mymps3
Disregard this post. I was losing my mind :(
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Am I going crazy but are HIGH and LOW opposite with these 2 chips.
Examples LOW 1 (makes led go OFF on 18x)
LOW1 (makes led go ON on 40x2)
I'm using common ANODE RGB led's
Many thanks!!!!
It all depends on how the LED (with resistor) is connected...
Direct picaxe connection:
a) Connection between picaxe and +V will require a LOW 1 to turn the LED on.
However, if you're using a project board which has a darlington driver, then the output will be inverted, so the following applies...
Darlington driver output:
b) Connection between darlington driver output and +V will require a HIGH 1 to turn the LED on.
Back
