Found Dry joint in wiring to Compass
Have now repaired same and things looking a lot better
Terminal appears to register directions.
I will continue with your help!! which is much appreciated
I would like to be able to send direction data to an Open Log instead of the terminal
I have 2 ports available C.3 and C.4
Could you recommend the correct code to achieve this !
I also would like to program in a delay between acquisitions
Your and others have been very good with your advice
Thank You,
John
Thank You,
John
