Hello forum
I am looking for a scheme to create a solar tracker
Can someone help me, I would like a program for 18M2
thanks
I have designed several of these and built as many, after much research and testing the assumption i have concluded to is it is best not to use light sensors and just track on the time of day with 2 or 3 programs to suit the changes throughout the year.
Outside of 1 axis tracking the percentage of gain for cost falls away rapidly, a single axis tracker can add 25-30% increase and a second axis might add 2-5% gain there after, when the sums are done its cheaper to add a extra panel than the second axis.
The sun travels a steady path of consistant travel so time is far good enough for tracking, where light sensors can cause hunting with cloud cover and also use more power than just a simple timed movement.
Im sure many will disagree, but i would like to see their logged data to back up any trials and testing they have done to prove me wrong.
This one? http://www.instructables.com/id/Arduino-Solar-Tracker/step4/The-Code/On the Web I've seen a circuit for this purpose but with a arduno.
Use the design in the link above.I can build a circuit. But not design
Why preferably an 18M2 ?But I mean a solar tracker in one direction from east to west,
with a scheme based on a piaxe, preferably one with a 18M2
program for that circuit.
Problem #1 is the large foot print it will take up due the spacing needed between panels to prevent shading.thinking a bunch of front forks with one panel per and chain and sprockets to couple to common motor drive ...] - We have big winds here on the edge of the Rocky Mountains so wind loading is a consideration.
I'll go with the fellow sun belt posters too- that's assuming you mean photo voltaics (PV) rather than solar heated water. It would greatly help if you specify the scale of your setup too - Watts or KW?! Are you after attractive Feed In Tariff (FiT) benefits that may apply in Belgium? I'll assume you mean kW...
With PV prices around US$5 a Watt (& falling thanks to the Chinese...) it's increasingly more cost effective to just add extra panels,which can be firmly & discretely attached to suitable roof tops. In contrast to such "fit & forget" systems, tracking systems (although entrancing) may need ground level mounting, & rugged costly mechanicals that are prone to wind damage/frayed wiring/rust/insects & animals (& wayward humans!) etc.
A key daily issue can relate to the local solar resource anyway. Morning cloud/mist/tree & building shading/terrain etc may mean a mechanical tracker blindly follows virtually a solar ghost, while afternoon sunbeams (which extra panels could better exploit) may go begging. Air clarity,panel temperature & UV levels may be significant too. During heavy cloud,rain or snow your tracker will keep working of course & may wastefully take more energy to do so than you collect...
Seasonally it's worth stressing that low angle winter sunshine is usually far more valuable for off grid systems than in high season. Summer electrical demand may be lower (as fewer lights etc) in many regions too. I've an off grid mate here in NZ (latitude 41 South) who has his batteries "virtually boiling" in summer, yet in winter the then poorly slanted PV panels are gasping to even trickle charge. His dwelling's roof pitch (& his age!) is a tad daunting & doesn't suit seasonal adjustment. With rapidly falling PV costs it's however become tempting to just add a further bank of suitably winter slanted PVs onto a steep pitch shed roof. Stan.
EXTRA: Check this highly informative FiT slanted Australian site,which indicates single/dual axis tracking may increase output by ~20-30% for kW level systems. This however may NOT be cost effective (trackers may cost as much as the PVs!),& the 2010 calculations are now hazy due to lower PV prices & reduced FiT payments too. In contrast, mechanical tracking supply/installation & maintenance costs have probably increased.
The author sums things up by saying- For small 1.5kW installations the upfront cost of a tracker is high, and the payback period is long. In reality, investing the same amount on additional solar cells would yield higher generation volumes, more income, as well as greater environmental benefits..
Gee Stan you need to shop around, I looked at 250w panels a few days ago for $0.50 a watt (Chinese made) and settled on some high quality panels for $0.80 per watt (German made).& panel costs below US$2 a Watt are now common
Nice find- what is your source? Is this nominal rating justified however?250w panels a few days ago for $0.50 a watt (Chinese made)
I have been involved with testing of some Micro Inverters, and would argue the opposite of a 40% gain.lots of microinverters seem to be appearing [one per panel and grid tieable]. A recent comment from the editors of HomePower magazine indicted up to 40% overall gain in far latitudes
What can i tell you other than it was trade pricing given to me from someone i know in the solar bussiness. (goes to show the price mark up some add)But let's have details of those 50 - 80 cent a Watt 250W panels please!
A possibility :-Gentlemen, I have been unable to find a reference that someone made to a PICAXE project to monitor and charge control a battery within a battery group with a solar recharger. I believe these batteries were destined for an automotive application. There was a networked (I2C?) set of PICAXE boards with overcharge loads on them to keep from overcharging the batteries. Each battery had a board, but all the boards were connected to this network.
The link I've lost goes to this person's web site about the project, but I have been unable to filter through all the search references and find it.
Anyone know what I'm trying to remember?
@SAborn - aside from installation and heat issues was it your finding the micro-inverters were just deficient in efficiency over usual power solar insolation conditions? [there are also cases where partial shading issues come in play - forget those as well].
Did you try more than one brand? Could you say what brandyou tested? Thanks
I'm pretty sure this is Peter Perkins BMS project, linked to above (his username here is retepsnikrep). It used a small 08M board on each cell, networked via a daisy chain serial link to a master control board and display.Sorry, (I do think this is pertinent to this thread) the batteries were rectangular like gelcells or lead acid. Thus, the universal interest in the project. The PCBs and buss bars were all on the top of the batteries. (I hope my memory is working right.)
