I have been using this circuit to turn on an intake motor in my race car for 2 years. Recently I have experienced two failures of the FET which I think is heat related.
I need some help getting the PWM values right. I am supplying ground via the FET to the motor to turn it on and keep it on/off at set engine RPM's.
I need a pretty strong turn-on torque/current then not too much to hold it on.
The FET is a IFRZ44V. I've tried various PWM settings but really I'm just guessing what the FET is happy with.
Help appreciated.
Help appreciated.
RPMActions:
'Sets the SPIMotor signal depending on the Av RPM value.
'ON ENTRY: AvValue holds the new Average RPM value
'If the new Average RPM is greater than the RPMHigh threshold then output
'a PWM signal. If it's below the RPMLow threshold then turn the PWM signal
'off. This gives it some hysterisis and stops the motor from oscillating on and
'off when the value is hovering around the threshold.
If AvValue > RPMHigh Then
PWMout SPIMotorPin,199,520
'high LEDOutput
Elseif AvValue < RPMLow Then
PWMout SPIMotorPin,0,0
'low LEDOutput
Endif
Return
