I'm trying to program both an 08M and and 18x. I'm using a serial to USB adapter with the prolific chipset.
If I try using this on an XP machine, it will work either on the serial port, or using the adapter to the USB port.
At home however I have two PC's. A desktop with Windows 7 64 bit, and a laptop with Vista 32 bit.
-Windows 7
Everything seems correct, but the program will rarely finish downloading. It will stop at random places with an error as if the voltages aren't correct, or the connection has been lost.
-Vista
I can't even get the firmware check to work. I get the 0x1F54 comm error. I've found threads mentioning a change in drivers to the 2.0.0.7 version that fix this problem. When I download from the link located here http://www.rev-ed.co.uk/picaxe/software.htm something isn't right. Pointing the PC to the folder says that there is no driver there.
Any help on getting this to work on either PC?
(If it would be of use, I also have Ubuntu on the Windows 7 machine, but I'm still new to Linux)
-Windows 7
-Vista
