help in programming needed.
klz
I'm using a 28X picaxe board. I need to design a program to control the motors through relays.
PROGRAM:
Inputs: pin0 is for ON/OFF purpose
pin1 is for sequence purpose
Outputs: high/low 0 and high/low1 (temporary use on LEDs on the board to see the different sequence)
label_1E: 1st sequence
label_25: 2nd sequence
label_9B: 3rd sequence
label_CF: return to 1st sequence
When input pin0 is pressed then 1st sequence is executed. Then, when the sequence1 is interrupted by the pin1 button. It will jump to the interrupt program and return back to the point it was interrupted after the interrpt program is executed. So everytime the pin1 is pressed, it will change sequence.
PROBLEM: I do not how to program the program such that when the pin0 (ON/OFF) is pressed then the currently whole program will stop until the pin0 is pressed again the next time. Can use another interrupt for the ON/OFF?
HELP!!!
'BASIC converted from flowchart:
'C:\DOCUMENTS AND SETTINGS\STUDENT\DESKTOP\MM.CAD
'Converted on 9/20/2007 at 13:59:23
setint %00000000,%00000010
label_6: if pin0=1 then label_6
label_1E:            high 0
                        wait 5
                        low 0
                        wait 5
                        if b1=0 then label_1E
label_25:            high 1
                        wait 1
                        low 1
                        wait 1
                        if b1=1 then label_25
label_9B:            high 0
                        wait 1
                        low 0
                        wait 1
                        if b1=2 then label_9B
label_CF:            let b1=0
                        goto label_1E
interrupt:            b1 = b1 + 1
                        pause 2000
Thank you.
Something like this may help. Note the switch will only be read once per loop.
label_1E:            high 0
                        wait 5
                        low 0
                        wait 5
                        if pin0=0 then reset_it
label_25:            high 1
                        wait 1
                        low 1
                        wait 1
label_9B:            high 0
                        wait 1
                        low 0
                        wait 1
label_CF:            let b1=0
                        goto label_1E
                        pause 2000
reset_it:            ; wait until switch released again
                        pause 10
                       ; switch has now been released
                       ; wait 10ms to debounce switch
                       ; then loop back to start
                        pause 10
label_1E:            high 0
                        wait 5
                        low 0
                        wait 5
label_25:            high 1
                        wait 1
                        low 1
                        wait 1
label_9B:            high 0
                        wait 1
                        low 0
                        wait 1
label_CF:            let b1=0
                        goto label_1E
                        pause 2000
                        pause 10
                        pause 10
Hi.
Is there another faster way to check whether the ON/OFF switch is pressed? Because if the period of 1 loop is 10 secs then I have to catch the exact time the loop finishes and pressed the switch at the same moment for the program to work.
label_1E: high 0
wait 5
low 0
wait 5
The waits can be broken down into smaller delays e.g 'wait 5' can become
for w5 = 1 to 500
pause 10
next w5
This will check the switch every 10ms. Remember to use a word variable if the number of for...next loops > 255
Back
