hell.p 20m2 pin c.7
late_voyager
Hi
I have a project looking at 3 inputs on a 20xm2.
checking c.4, c.5 and c.7... just run simple prog to check all inputs, all work but c,7.
tried new chip, solder joints etc even went direct to pin.. same all but c.7
am i missing something with the input of the chip?
if pinC.4=1 or pinc.5=1 or pinb.6=1 then high b.7
pause 50
low b.7
late_voyager
C.7 doesn't appear anywhere in your code. Could that be it? :)
hi sorry changed it to b.6 to see if that was working, thats ok.
returned code... same :(
Main:
debug
low B.5
if pinC.4=1 or pinC.5=1 or pinC.7=1 then high b.7
pause 50
low b.7
erco
If it worked using b.6 it clearly should work with c.7. Bad wiring? C.7 is adjacent to the Serial In programming pin, which is pulled low through resistors. Maybe a solder blob connecting?
erco
Run program while connecting C.7 to ground and +5V.
sertxd (#pinc.7,13,10)
late_voyager
hmmm when i run this it works
Main:
debug
serout C.0,N2400,(254,128) ' move to start of first line
serout C.0,N2400,(#pinc.7,13,10)
if pinC.4=1 or pinc.5=1 or pinc.7=1 then high b.7
pause 50
low b.7
late_voyager
but this it dont..
init:
pause 200
FVRSETUP FVR2048   'Set Fixed Voltage Reference = 2.048 Volts
ADCCONFIG %011     'Set ADC to FVR
Symbol batt = w1            ; Word variable for the calibadc10 reading
calibadc10 batt            ; Take the reference reading
pause 20
Main:
debug
low B.5
pause 50
low b.7
' relay 1 top B.5
' relay B.6
elseif pinB.1=1 and pinB.2=0 and pinB.3=0 and pinB.4=0  then
    serout C.0,N2400,("relay            ")
    goto p_relay
elseif pinB.1=0 and pinB.2=1 and pinB.3=0 and pinB.4=0  then
    serout C.0,N2400,("sensor            ")
    goto p_relay
else gosub volt
p_buzz:
high B.7
pause 50
Volt:
readadc10 B.0, batt '3.5v batt
    batt = batt *17
      bintoascii batt,b4,b5,b6,b7,b8
readadc10 C.2, batt ' 24v batt
        batt = batt  *27
      bintoascii batt,b12,b13,b14,b15,b16
    serout C.0,N2400,( "PLUG IN CABLE.. "   )
    serout C.0,N2400,(254,192)
    serout C.0,N2400,("Batt ",b13,b14,"v - ",b6,".",b7,"v ")
p_relay:
' relay 1 trigger B.5
' relay 2 trigger B.6
' relay s2 in C.4 centre pin NC
' relay s3 in C.7 bottom pin NO
    serout C.0,N2400,("RELAY TEST           ")
    serout C.0,N2400,("     wait...     ")
    pause 50
if pinC.4 = 0 and pinC.7 = 0 then
    serout C.0,N2400,(" *** a *** ")
    pause 20
elseif pinC.4 = 1 and pinC.7 = 1 then
    serout C.0,N2400,(" *** b *** ")
    pause 20
elseif pinC.4 = 1 and pinC.7 = 0 then
    serout C.0,N2400,(" *** c *** ")
    pause 20
elseif pinC.4 = 0 and pinC.7 = 1 then
    high B.5 ' relay 1 (top)
    pause 2000
    serout C.0,N2400,("   PASS PASS    ")
elseif pinC.4 = 0 and pinC.7 = 0 then
    serout C.0,N2400,(" *** FAILED *** ")
    pause 20
    pause 20
low B.5
pause 500
late_voyager
run this and dont work...
init:
pause 200
pause 20
Main:
debug
pause 50
low b.7
late_voyager
this works....
Main:
debug
pause 50
low b.7
late_voyager
when i rem the calibadc10 batt ; Take the reference reading
it works??
init:
pause 200
'calibadc10 batt            ; Take the reference reading
pause 20
erco
Hmmm. Not sure about this one. Unlike C.4 and C.5, pin C.7 has ADC capability, possibly related. Is it an option for you to use input-only C.6 instead of C.7, or have you made a million of these PCBs already?
erco
He wants C.7 as input.
@ LATE_VOYAGER: Just for sport,, try INPUT C.7 after CALIBADC.
Right on the first, close on the second.
It appears that the CALIBADC is turning C.7 into an ADC Input and, once that's done, the C.7 digital input always then reads low.
Adding an "adcsetup=0" turns off the ADC settings, restores inputs back to digital usage, including the ADC on C.7. This works for me on a genuine 20M2 firmware 8.A chip -
Rich (BB code):
#Picaxe 20M2
Init:
  FvrSetup FVR2048
  AdcConfig %011
  CalibAdc10 w1
  adcSetup = 0 ; Restore C.7 to digital input use
MainLoop:
  Do
    If pinC.7 = 1 Then
      High B.7
    Else
      Low  B.7
    End If
  Loop
erco
Most excellent work, hippy! How nice that late_voyager, a new member, discovered a singularity in the fabric of space-time.
