Andrew Cowan
Apparently, if you toss a UK penny 10,000 times, it will land as heads 4950 times, and tails 5050 times. I realise that this result isn't statistically significant, and a MUCH larger sample size is needed. This question purely theoretically - I don't plan to do it as I don't have the time or resources.
Here's the question:
How would one make a penny flipping machine (robot?), which must:
Problem 1 - Flipping the coin
To flip the coin without bias is a hard thing to do. My current thought is to drop the coin from a vertical position, then let it fall a short distance (~1m), where it lands on its side.
Problem 2 - Collecting the coin
The base of the platform could tilt, sliding the coin to the measurement area.
Problem 3 - Determining the side
I can't think of anything other than colouring one side black with a pen, then checking to see how much light each side reflects
Problem 4 - Repeating
Either the coin needs to get back to the drop rig, or there needs to be a large supply of coins. If there are lots of coins, then this makes my answer to problem 3 very time consuming!
As I said, I see that this isn't possible to do, but how could you do this test with 50,000 coins?
A
- Flip a penny, in an entirely random manner.
- Collect the propped coin.
- Determine if it is heads or tails.
- Increment a counter
- Repeat
A
