erco
Needed an H-bridge for a small 12V motor but my favorite cheapie MX1508 H-bridge is only rated for 10V, so I grabbed an L9110S. Per info at https://arduinodiy.wordpress.com/2019/11/02/mx1508-vs-l9110s-vs-l293-motordriver-board/, it appeared to be up to the task since it mentions 12V use with logic-level signals: "That means that if you use 12 Volt DC for the motor and a 3v3 microprocessor to control the motor, on a LOW level there will be possibly flowing 1.2 mA into the uC pin."
Unfortunately the L9110 module got quite hot when 5V signals were applied, even without any motor connected. A second module behaved the same, so I moved on the TB6612 also mentioned in that article, which has separate inputs for motor (Vm) and Vdd. I had never tried these, but I had a few a couple tucked away (being a hoarder has advantages) and I'm pleased to say that it worked perfectly the first time. Erco-recommended, grab a few for your bench for a rainy day.
I despise L298 H-bridges, they are so inefficient. IMO all of these much smaller modules are better, and their current ratings are impressive for their size. Also all are dual H-bridges, and available for a buck or so if you shop around.
L9110=800mA, TB6612=1200mA, MX1508=1500mA.
