Hi, I'm having a tough job getting this to work, so if any of you out there are using a picaxe connect and a GPS moduule, read on.
I want speed over ground in KPH and Altitude. I wrote the code below but it just sits there and waits, so it is not reading the data. I have looked with a scope, signal is there OK, on pin 16, but it won't budge. At this point I'm wondering if it is something silly, but I can't see what. If you have this set-up, or would like to comment, go ahead. The GPS is working fine with LSviewer and is set to only send these two 'words'.
init:
serout 6,N2400,(254,1) 'clear LCD
pause 30
serout 6,N2400,(254,128,"Chip running"![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
pause 30
serout 6,N2400,(254,128,"Main Loop start"![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Pause 1000
pause 30
serin 7, N4800, ("$GPVTG,"
, b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b1,b2,b0,b4
'total of 26 charcaters to dump before the data we actuall need, KPH up to 99.9!!
serout 6,N2400,(254,128,"KPH=",#b1,#b2,".",#b4) 'show it on LCD
Pause 100 'now do the elevation buried behind 48 b0's!!
serin 7, N4800, ("$GPGGA,"
, b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b1,b2,b0,b4
serout 6,N2400,(254,128,"Ele=",#b1,#b2,".",#b4) 'show it on LCD
pause 100
HELP!!!
Gareth
init:
pause 30
pause 30
Pause 1000
pause 30
pause 100
HELP!!!
Gareth
