Bayside888
Active member
First of all, thanks to Flenser and bpowell for their comments to help get this project started. It reads a pressure and a temp sensor and stores the data in regular intervals, then downloads to a terminal for storage when a button is pressed.
It works just right when storing to the internal PicAxe data locations, but that limits the amount of storage space. The read/write commands are shown below, commented out. So, now I amusing a 24LC128 EEprom with the hi2cout and hi2Cin commands. The circuitry works, because I get good data out when the variables are just byte-sized. However, I get large (65,000+/-) values when the data stored are larger than 255. This may be a very simple problem solved many times, but I can’t find the answer after diligently searching the forums. I believe I need to somehow combine the byte values to make a word, but? The problem is likely in the last couple of lines, but I have included the preceding code. Regards:
[CODE] #PicAxe 28X2 hi2Csetup i2cmaster, %10100000, i2cfast, i2cword 'for 24LC128 EEprom.Symbol holdvalue1 = W3Symbol Temp_value = W5Symbol sensorvalue = W7Symbol counter = W8Symbol dataAddr = W13 'holder to keep track of storage location; ..; .. get pressure value from sensor = sensorvalue then store in 24LC128 holdvalue1=dataAddr 'next data set number; write dataAddr, word sensorvalue 'for saving to internal PicAxe eeprom hi2cout dataAddr,(sensorvalue) 'save to external EEprom dataAddr = DataAddr+2 'plus "2" for word variables pause 5 'pause for serial EEprom, next steps take another 5 ms ; .. get temperature value from sensor = Temp_value then store in 24LC128 ; write dataAddr, word holdvalue 'write word value of temperature toPicAxe hi2cout dataAddr,(Temp_value) 'save to external EEprom dataAddr = DataAddr+2 'plus "2" for word variables ; routine continues logging until user stops prgm ;------------------------------------------dump data to serial line-------------------------; this portion downloads all data in EEprom to terminal when a button is pressedData_dump: 'Hi2cin is always a bytesertxd("Button pressed",#dataADDr,cr,lf) 'shows location of last data; 'dataAddr saved from above to find last data dataAddr = dataAddr/4 'word variables use 2 locations dataAddr = dataAddr-4 'adjust to read back correctly holdvalue1=0 'start at first location for counter = 0 to dataAddr 'count data sets (not locations); read holdvalue1, word sensorvalue hi2cin holdvalue1, (b14,b15) holdvalue2=holdvalue1+2; read holdvalue1, word holdvalue1 ;for use with PicAxe internal EEprom hi2cin holdvalue1, (b10,b11) sertxd(#counter," Press=",#sensorvalue," Temp=",#Temp_value,cr,lf) 'send data holdvalue1=holdvalue1+2[SIZE=5] next[/SIZE]
