You can give a pin variable a name such as "Symbol LED = pinC.1" then you can used "LED=1" and "LED=0" to set the pin high and low.On the stamp code the outpin was given a name and declared as output. Then name = 1 was used in place of high name. To bad picaxe doesn't have this (that I know of).
There are Symbol declarations to give alias/alternate names to variables and IO pins.On the stamp code the outpin was given a name and declared as output. Then name = 1 was used in place of high name. To bad picaxe doesn't have this (that I know of).
