Hiya. Been fiddling with 8Ms for a couple of months now.
Is it possible to fry an individual pin in an 8M without otherwise hurting the IC? In other words, I send this
and I can't get a standard LED to flash off of Pin 5/Out 2, but if I change it to
and connect the LED to Pin 6/Out 1, it flashes merrily away.
Of course, this problem surfaces after I've been switching the output of Pin 5/Out 2 between different kinds of MOSFETs in order to drive a high-voltage (12v, 4a) bulb.
I've tried zeroing out the memory and reloading the code to no avail.
Any thoughts?
Thanks.
\dmc
top:
high 2
pause 500
low 2
pause 500
goto top
top:
high 1
pause 500
low 1
pause 500
goto top
Any thoughts?
Thanks.
\dmc
