Freeing up COM ports
mhalbern
I am using PE version 5.5.6. on a WinXP Pro SP3 PC.
In the Options menu, Serial port, there are devices (such as, COM 4 Belkin Serial on USB port) assigned to various COM ports that have not been used for months.
Is is possible to clear out these old assignments to free up the COM ports?
Thank you for a reply.
Click "Start" button and type in cmd<enter>
Type the following and then press enter
set devmgr_show_nonpresent_devices=1
Start the Device Manager via typing
start devmgmt.msc
Do not close the cmd prompt
In Device Manager
Select View>Show hidden devices
Phantom devices will now be shown.
Right click over the one you don't want any more and uninstall it.
mhalbern
The Device Manager only shows the physical COM ports and the virtual COM ports that are actively in use. This is not the issue of my posting.
Thank you.
Thank you.
No, when you have enabled visibility of phantom ports as described above it shows all, even those not connected.
mhalbern
Technical, I accidentally closed the cmd window before viewing the Device Manager. Oops, my bad.
I tried it a second time without success.
I also tried the command line with =0 at the end.
I have attached what I see on my PC.
Your help is appreciated.
mhalbern
Technical, I followed the instructions in the support page.
The key seems to be opening the device manager through the command prompt.
Success!
Thank you.
