Rich (BB code):
;TM1637_test.bas
#picaxe 08m2
;segment data for TM1637
;( 0 1 2 3 4 5 6 7 8 9 A b C d E F dash blank)
DATA 0,($3f,$06,$5b,$4f,$66,$6d,$7d,$07,$7f,$6f,$77,$7c,$39,$5e,$79,$71, $40, $00)
;for TM1637
symbol dio = C.1 ;TM1637 data pin to 08m2 leg 6
symbol clk = C.2 ;TM1637 clock pin to 08m2 leg 5
symbol D3 = b2
symbol D2 = b3 ;for all 4 digits
symbol D1 = b4
symbol D0 = b5
gosub brightness ;set display brightness
for b1 = 0 to 17 ;sequence thru all character
D3 = b1:D2 = b1 ;bytes stored in the data
D1 = b1:D0 = b1
gosub DISPLAY
next b1
end
;Group of subroutines to read the values from data and output to the display
DISPLAY:
;Enable sequential movement (from one digit to next)
call i2CStart
b0 = $40
call i2CWrByte
call i2CStop
;Move to first digit
call i2CStart
b0 = $C0
call i2CWrByte
;First value
read D3,b0
call i2CWrByte
;Second value
read D2,b0
if b1 = 17 then
b0 = b0 + 128 ;add 128 to turn on colon
call i2CWrByte
;Third value
read D1,b0
call i2CWrByte
;Fourth value
read D0,b0
call i2CWrByte
call i2CStop
i2CStart:
high clk
high dio
low dio
low clk
i2CStop:
low clk
low dio
high clk
high dio
;Send a byte
i2CWrByte: ;outpinC.1 = dio
outpinC.1 = bit0:pulsout clk, 1
outpinC.1 = bit1:pulsout clk, 1
outpinC.1 = bit2:pulsout clk, 1
outpinC.1 = bit3:pulsout clk, 1
outpinC.1 = bit4:pulsout clk, 1
outpinC.1 = bit5:pulsout clk, 1
outpinC.1 = bit6:pulsout clk, 1
outpinC.1 = bit7:pulsout clk, 1
pulsout clk, 1
;Set the brightness ($88 = on, $88 to $8F are the brightness levels)
brightness:
call i2CStart
b0 = $89
call i2CWrByte
call i2CStop
