For - next simulation problem
dennis
Using v 5.1 and the 28x1 I cant get a for next loop to simulate as the code seems to stop at next b1.
<code><pre><font size=2 face='Courier'>'for next simulator test
for b1=1to 10
sertxd(#b1,13,10)
next b1 </font></pre></code>
Is this my mistake os should I make a bug report ?
MORA99
are you missing a space between b1=1 and to ?
and I dont think you need/should have that b1 after next, just next will do
Edited by - MORA99 on 06/05/2007 18:13:55
dennis
I dont think that is the problem as the code passed the syntax test but this version will not run for me either.
for b1 = 1 to 10
sertxd(#b1,13,10)
next </font></pre></code>
Do you have similar results ?
Doesn't work for me either.
Just hangs on the 'next' line with b0 at a value of 1.
This seems to have happened since upgrading to version 5.1.0
Also fails for an 18X so it looks like a bug which has arrived with 5.1.0
