Hi
I am looking for a way to setup 3 potentiometers, so one of them is used as the "power dial"
one of them set the maximum value, and one the minimum.
the thing is, that it is not a voltage divider.
which means the ohm value is critical all the way. (not just the proportional 'travel' of the pot,)
I once saw an arrangement that would allow to tun the main diam to the minimum, then set the minimum tuning trimmer,
then set the main diam to maximum, and then set the maximum trimmer.
but setting the maximum trimmer won't change the value of the minimum level.
do you have any idea ?
