Farenheight Conversion
neiltechspec
I'm having a bit of trouble trying to convert to to Fahrenheit & displaying to one decimal place.
Currently using the following code which displays rounded value only.
	readtemp12 insens,temp12	;read raw into temp12
	if temp12 = 0 then		;check if DS18B20 responding
	  pause 750
	  serout tcpip,baud,("Indoor Sensor not found",cr,lf)
	sign = 43				;sign is "+"
	if temp12 > 2048 then		;check for below 0 deg
	 sign = 45				;if temp is below 0 sign is "-"
	 let temp12 = - temp12		;two's compliment
  	adjtemp = temp12 * 10 / 16
  	bintoascii adjtemp,b25,b26,b27
  	serout tcpip,baud,("Indoor Temp:  ",sign,b25,b26,".",b27,$b0,"C")
  	fht=adjtemp /10 *9 /5 +32      ;fahrenheit conversion
    	serout tcpip,baud,(" (",#fht,$b0,"F)",cr,lf)
This code is an extract from whole program (indoor temp, outdoor temp, windspeed & humidity).
Any help with the maths appreciated.
Neil.
cravenhaven
I think you have made the variable "fht" a byte variable. Try making it a word variable and you should see the solution to your problem.
Armp
BTW The calculation can be rearranged to handle temps down to 0F/-17.8C without overflow:
adjtemp = temp12 + 285 *9 / 8   ; Give Temperature in tenths degree F
temp12 = -285 (-17.8C) gives 0; temp12 = 0 gives 320; temp12=1600 (100C) gives 2120
neiltechspec
The problem was another of my silly mistakes.
I was converting the Celsius adjusted value instead of the raw 12 bit value.
I'm using -
adjtemp=temp12 *9 /8 +320
bintoascii adjtemp, etc...............
Works now.
Neil.
	  pause 750
Neil.
w0 = w0*9/5+32
