This is simply a program programmed in VB.NET that provides 'wizards' that are not (yet) in Programming Editor. It is Windows only and requires the .NET Framework and is compatible with Windows 98 onwards. It can calculate:
----------> Quick link to latest version <----------
Latest screenshot:
[hr][/hr]
First version screenshots:
Choosing to disable hserin and hserout at the same time causes the wizard to produce 'hsersetup off' in the command box and hides the baud settings, actual baud rate and error since those become irrelevant.
When the external clock is selected, the interval selection is replaced with somewhere to specify how many pulses are required to increment the timer variable.
The attachment is a zip containing an exe, rather than a renamed exe. The 'PICAXE Calculator' zip file contains the program and the sourcex.y.z folders contain the VB.NET source code including form code, form designer file, icons, bitmaps, project file and solution file.
To see how each command is calculated, see the source code for the latest version.
Comments, suggestions for improvements and extra calculators, and nitpicking are all welcome.
Licensing: Free for any use, but attribution required for reuse of original code.
Latest version at the end of this thread - the version below is the first version.
- hsersetup baud value (the actual values and error % on the PICAXE from using a non-decimal number)
- settimer preload value (the actual values and error % on the PICAXE from using a non-decimal number)
- hintsetup wizard (added in version 1.3)
- compsetup wizard (added in version 1.3, updated in version 1.9 to support all X2 PICAXEs)
- tmr3setup wizard (added in version 1.4)
- adcconfig wizard (added in version 1.5)
- dacsetup wizard (added in version 1.6)
- potential divider wizard (added in version 1.7, has ADC-to-Voltage multiplier calculation in version 1.8, has multiplier selection in version 1.8.3)
- resistor colour code wizard (added in version 1.7, has label showing resistance in version 1.10.3)
- dec/hex/bin/oct integer conversion (added in version 1.8)
- UPDATED interactive bitmap lookup/table/eeprom command generator (added in version 1.10, has and/or/xor/not operands in version 1.10.1, updated in version 1.10.2, has import function in version 1.11, has maximize/minimize feature in 1.12.1, fixed flicker in 1.12.2, supports C-style arrays in version 1.13)
- setint wizard (added in version 1.12)
Latest screenshot:
[hr][/hr]
