I have a 28X1 that im trying to design a multi bank EEPROM storage solution for. (not really for practical use, just as an i2c learning experience). Most if not all 24LCxxx parts have the three address pins on them. I have most of the hardware part down, and as for the software end, i've hit a wall, i scoured google and couldn't find info anywhere.
i need to know how the relation between the pins and the software address works. Is it a simple binary system? If tying all three pins low gives you address 0, would pin 0 high and pins 1+2 low give you address 1? would 010 be address 2 so on and so forth? also how would that relate the the address in the code? Address 0 = %00000000, address 2 = %00000010, address 3 = %00000011? This is what i've come up with on my own, and assuming this is how it works. but seems every time i act upon an assumption, things either don't work or have a catastophic meltdown.
