Mycroft2152
VSM can export schematic files to pcb programs in one of 2 ways. If you own Labcenter's ARES or Rev_Ed's RealPCB, it is a simple one click operation. For any other pcb program, the schematic file is exported as a NETLIST.
NETLISTs consists of 2 parts, a list of all the connections and a a list of the component footprints to use. Depending on the NETLIST format, it may be a list of names (TANGO), or just a list of IC designations (Multiwire used for EAGLE)
The component footrpint names are native to ARES and have to be "interpreted" for other pcb programs. When a NETLIST is imported and the pcb program cannot find the named footprint, you must select the appropriate footprint from the the pcb library.
Unfortuanately, this has to be done on a component by component basis, each time you import a NETLIST. A real PITA.
The solution is to rename your pcb program's footprint's to match the ARES names.
I am creating up a DIPTRACE (a free pcb program) VSM footprint library and have had to analyze the VSM/ARES footprint library. There are most components will use one of 72 footprints, but there are a number of addtional components in VSM that do not have an associated foootprint.
CELL
DPSW2
IRLINK
KEYBOARD3X4
KEYBOARD4X4
MOTOR-BISTEPPER
MOTOR-BLDCM
MOTOR-SERVO
SW-DPDT-MOM
SW-DPDT
SW=DPST-MOM
SWDPST
SW-ROT-3
SW-ROT-4
SW-ROT-5
SW=ROT-6
SW-SPDT
SW-SPDT-MOM
SW-SPST-MOM
SW-SPST
With these missing footprints, even even exporting schematics to ARES will not be complete. This isalso true for RealPCB, except some VSM components have a Realpcb name but no ARES equivalent. (?)
Technical / Labcenter can you fill in the gaps in the footprint list?
Mycroft2152
PS. If anyone wants to try out a BETA version of the VSM DIPTRACE library, you can contact me through the forum. when the library is completed, I will post it.
CELL
DPSW2
IRLINK
KEYBOARD3X4
KEYBOARD4X4
MOTOR-BISTEPPER
MOTOR-BLDCM
MOTOR-SERVO
SW-DPDT-MOM
SW-DPDT
SW=DPST-MOM
SWDPST
SW-ROT-3
SW-ROT-4
SW-ROT-5
SW=ROT-6
SW-SPDT
SW-SPDT-MOM
SW-SPST-MOM
SW-SPST
Mycroft2152
