Hello All,
Hope one of you could help, I have been trying to get my PICAXE-28X2 Shield (AXE401) to work again, Been using this for few years now to prototype projects.
Last I used this board was back in Jan 2020 but it fails now to program. I get the "Hardware not found on COM8!" error.
Whats confusing is, the same setup (ie Same PC, Editor, COM port, programming cable etc) works fine with a 8M device. I can program it successfully (and not a 28x2 device). I am using Windows 10 and PE6.
I have already tried few new 28x2 devices, tried the "hard reset" options both using power-up during programming and using reset pin on 28x2 but nothing worked so far.
Also noticed that, when I connect the AXE401 shield to a COM terminal, I get the following message. Which shows the 28x2 is able to send messaged back to PC.
Any help to resolve this issue is appreciated.
PS: I can see similar issue is being discussed here but its still open.
Thanks,
Gopan.
Thanks,
Gopan.
