Error: Loop without do
Gramps
What causes this error??
loop:
Syntax error on line 13 at/before position 4
Error: Loop without Do
#picaxe 18m2 ; type chip used
;setfreq m4 ; All M2 parts internal k31,
; k250, k500, m1, m2, m4, m8,m16,m32
symbol control = C.1
symbol val = w0 ; word (16-bit) user variable
symbol pwmPin = B.3 ; use only B.3 or B.6
init: ; setup PWM
pwmout pwmdiv4, pwmPin, 124, 1023
loop:
; readadc returns 8 MSB if used
readadc10 control, val ; get 10-bit value
; read 10-bit ADC into variable w0
pwmduty pwmPin, val ; set pwm duty
goto loop ; loop back to start
Thanks, Gramps
code captured from bristolwatch.com
'Loop' is a reserved word, and it needs a corresponding 'Do' to work.
Simplest solution is rename the two occurences of 'Loop' to 'Myloop',
Or replace the first with 'Do', and change delete 'goto' to make just 'Loop'.
See page 62 in Manual 2 for explanation of 'Do .. Loop'.
Also, the website is bristolwatch.com, not bristolwathch.
( The website author says every project has been built and tested, which project is this code from ? )
Cheers,
