Enhanced Download Circuit
Pongo
I noticed the Enhanced Serial Download Circuit is marked "(NB: Obsolete, for info only)". Does that statement assume that nobody uses a real RS-232 serial connection any more, or does it mean that the standard circuit is OK for use with a full spec serial connection?
The standard circuit has always been fine for full voltage RS232 as well. The enhanced circuit is only really of added benefit when trying calibration of touch sensors / adcs etc when using full voltage RS232.
If using AXE027 or other brand logic level cables it is of no benefit.
Pongo
Thank you for the explanation. I'm almost always using serial ports and have used the enhanced, but now I see don't always need to do that :)
