emailing to the forum
AllyCat
I don't know about "emailing" to the forum, and it may depend on the "User Interface" or "App" that you're using (Windows PC, Apple, Android phone, etc.) but you should have an "Attach Files" (paperclip) button below the window you've been typing in.
Alternatively, you can often "Edit > Copy" files, or put things into the "Clipboard", and then "Paste" (Edit or Right-Click) them directly into the Forum Editing window. And have you tried "hovering" over the icons at the top of the Editing Window to see what they can do? Note the forum also has a "Sandbox" if you want to try things out without directly posting to us.
When you start a new post at the bottom left of the post window there is a “button” labeled “Attach files” and a paper clip symbol which you can click on to attach a file such as an image/photo.
Within that process there is an option to place the image into the body of the post as opposed to showing only as a file icon at the bottom of the post
neiltechspec
It's actually this to insert an image. Or as mentioned previously, the paper clip to attach a file / files.
24441
Neil.
