eeprom command within case structure
mjy58
Just modified some code to save data into eeprom so it can be used between power downs and go this compiler error:
eeprom 112,(4)
Error: EEPROM cannot be used within If blocks
This looks fairly fatal for this construct. Couldn't find it documented anywhere, is there any way round it?
Extract of relevant code:
if verify < 14 then
    tagno=tagposition/14+1
    select case tagno
          case 1
    end select
    select case tagno
    case 1,3
    case 2,4
    case 5
    case 6
        dfeedcountlimit = foursecs / dmotortime
        eeprom 112,(4)
        cfeedcountlimit = sixsecs / cmotortime
        eeprom 113,(6)
        high Feed
        pause onesec
        inctime = inctime + 1
        low feed
    end select
nick12ab
The eeprom command only writes data to EEPROM when the program is downloaded - to write data to EEPROM at runtime you must use the write command. You then need to use the read command at startup to retrieve the saved value.
mjy58
Thanks Nick, I had used read earlier, but somehow forgot about write:eek:
Malcolm
