DS1307 Flash Memory Usage
lbenson
#1
I have a program in which it is useful to save data across downloads while I am doing testing. The only external flash I have is that in the DS1307 Real Time Clock (RTC) chip, 56 bytes in locations 8 through 3F. Putting data there is fairly straightforward, but I thought I would post the following code which tests the process. First it fills scratchpad locations 16-72 (decimal) with A-Z,a-z, and 0-3 (56 characters). Then it moves this data to 1307 locations 8-3F using subroutine copyScratchToRTC. Then it zeros the scratchpad. Then it moves the data back from the 1307 to the scratchpadcopy using subroutine RTCtoScratch. Finally it displays the scratchpad data. I am moving only printable characters, so I use the null character (binary 0) as a string terminator. If the subroutines encounter the null character, they stop moving data at that point; otherwise they move 56 characters. The variable, rNextSensorLoc, is used in my main program to hold the next available scratchpad location for holding data.
' 28Flash copies 56 bytes from scratchpad to DS1307 & back
#picaxe 28X1
symbol rNextSensorLoc = 0x64
start:
  i2cslave %11010000, i2cslow, i2cbyte
  ptr = 16
  for b0 = "A" to "Z" ' fill scratchpad with data
    @ptrinc = b0
  next b0
  for b0 = "a" to "z"
    @ptrinc = b0
  next b0
  for b0 = "0" to "3"
    @ptrinc = b0
  next b0
  poke rNextSensorLoc, ptr
  @ptr = 0 ' terminate string
  gosub copyScratchToRTC
  ptr = 16
  for b0 = 0 to 56
    @ptrinc = 0  ' zero out the scratchpad
  next b0
  gosub copyRTCtoScratch
  ptr = 16
  sertxd(@ptrinc,@ptrinc,@ptrinc,@ptrinc,@ptrinc,@ptrinc,@ptrinc,@ptrinc)
  sertxd(13,10)
  end
copyScratchToRTC:  ' rtc bytes 8-3F
  peek rNextSensorLoc,b2
  ptr = 16
  if ptr < b2 then
    b3 = 8
    do while b3 < 64 ' 3F=63
      if ptr = b2 then
        writei2c b3,(0) ' terminate string
        exit
      writei2c b3,(@ptrinc)
      inc b3
    writei2c 8,(0) ' terminate string
copyRTCtoScratch:  ' rtc bytes 8-3F or null terminated
  ptr = 16
  b3 = 8
      readi2c b3,(b4)
      if b4 = 0 then exit
      @ptrinc = b4
      inc b3
    poke rNextSensorLoc,ptr  ' save next location
#2
Wow, great timing. I just ordered a DS1307 Real Time Clock module and this will come in very handy. Do you know if there are any other general purpose PICAXE routines to support this RTC chip such as loading initial time, etc?
Lefty
lbenson
#3
I think those are covered in other threads in the code snippets section. In the Program Editor you can click Help, PICAXE 28/40 Datasheets, i2c tutorial--it has a section on the 1307.
Briefly, to initialize you do:
writei2c 0, ($00, $42, $23, $03, $15, $10, $08, $10) ' smhwdmy
The bytes written are seconds, minutes, hours, weekday, day, month, year, control. The hex values show the BCD numbers, e.g., the 15th day of the 10th month of the year '08.
To read:
readi2c 0, (b0,b1,b2,b3,b4,b5,b6) ' smhwdmy
To convert the day of the month to two ascii characters:
bcdtoascii b4, b7, b8
In the above example, b7 would be "1" and b8 would be "5".
To convert those to binary:
b9 = b7 - "0"
b10 = b8 - "0"
To make a single binary number of the two digits:
b11 = b7 - "0" * 10 + b8 - "0"
Enjoy.
