I have just acquired a size 23 Hybrid Stepper Motor (Astrosyn MY23HS2-2) and I want to drive it using a PICAXE. I have driven smaller motors successfully, but I would be grateful for a little advice to check that I am thinking along the right lines with this one...
The motor is an eight lead type so can be driven either Unipolar or Bipolar.
The Phase Current is specified at 1.0A and the Phase Resistance is 6.2ohms.
Therefore my understanding is that to drive this without current limiting I should be looking at 6 volts for unipolar drive and 12 volts for bipolar drive to sustain one amp phase current. An L293 (not L293D) is specified to drive 1amp per channel with a 5ms peak of 2 amps. I would like to use the L293 as a bipolar drive with the necessary external protective diodes rather than upping to an L298 simply because the former is easier to work with. Before I set it up and try to discover for myself at the risk of burning out some L293s, could I ask for advice or experience, please?
A further question; I do have some 2 amp 4-phase unipolar stepper motor driver boards (RS Components, 217-3611) which operates at 12 volts but requires a current limiting resistor placed between the board and each phase winding - in this case it would be a 6 ohm resistor rated at 10 watts. With a mind to more sophisticated driver units that offer adjustable current limiting on board, I am thinking of using an LM317 wired for current limiting as a substitute for the resistor. A commentary on this approach would also be most welcome.
(edit) I have just read one of the references given by Westy in his most well-written tutorial on stepper motors which states "The performance of a motor run with a current limited power supply is noticably better than the performance of the same motor run with a resistively limited supply" therefore this reinforces my second question - is the LM317 the right way to achieve this?
