Bayside888
Active member
I can program the PICAXE fine with the little "breadboard cable adapter", but can't get a PCB circuit to work. I laid the PCB out as in the Manual and the AXE027 manual, tested the connections, resistors, etc. I finally soldered in two hooks to pin 6 and 7 of the 28X2, use the little breadboard adapter, and it programs fine. I even switched out the female 3.5mm socket on the PCB, still no go. Anyone have any ideas? Thanks
