I tried to program an 08M using the AXE026 download cable - the one that connects to the laptop serial port. All a bit retro but there were reasons.
I got "Hardware not found" error so I ran the Download Cable Test. It passed the continuity test but the Voltage test showed +5.8V when 5V was expected and -5.6V when 0V should have happened. Does this show that there's a fault with either the cable or the serial port?
Subsequently I checked the 08M with the AXE027 USB cable and it still was Hardware not found. Other chips were OK so I presume this 08M is kaput. Could the download cable be the cause? The chip has been around for a long time and its history is uncertain so it's quite feasible that it was damaged before.
Derek
Derek
