Roseandthistle
Hello again, All!
My new project is a double slip switch on a garden railroad. I have decided to use the Axe020 board on this project. I have 8 inputs, 2 from each switch machine, either/or.
One position is straight (green) the other position is divergent (red). I figure I have 32 output possibilities. I need help with led fade in/out, flashing, and figuring out what is
best; GOTO SUB, IF THEN ELSE, or CASE SELECT.
If the correct switches are switched (divergent) then those signals will flash red, while the other 2 switches will display solid red. If all switches are set to straight thru, then all signals are solid green. If all switches are divergent the all signals will be red.
Thank you
Terry
Thank you
Terry
