Disability Aid
RNovember
Well-known member
#41
So I just want to to get everything right.
1. All that needs to happen is that if one button is pushed, its LED comes on, and all the other LEDs are switched off, regardless of the order that the buttons are pressed.
2. There needs to be three inputs, one from each button.
3. There needs to be three outputs, one to each LED.
4. It needs to work! :)
Am I right in suspecting this, if so, let us know.
#42
doesn’t matter if the wrong button is pushed the same corresponding single LED lights. The teacher notes that the student didn’t copy the number pattern that she did
That makes sense. So it really is a case of push any button, light the corresponding LED.
The following code will work in simulation and should on an actual chip. It turns the LED on which corresponds to the button pushed, turns them all off after two seconds of no push, for when the teacher has entered her sequence, and after the child has repeated it.
#Picaxe 08M2
#No_Data
Symbol LED1       = C.2
Symbol LED2       = C.1
Symbol LED3       = C.0
Symbol BUTTON1    = pinC.3
Symbol BUTTON2    = pinC.4
Symbol BUTTON3    = pinC.5
Symbol PUSHED     = 1  ; Active high buttons
Symbol timeout    = w1 ; b3:b2
Symbol buttonPush = b4
Symbol wanted     = b5
Symbol NONE       = 0  ; No button pushed
Symbol TIMEOUT_MS = 2000
Disconnect ; Because we are using C.5 as an input
Gosub TurnAllLedsOff
Do
  Gosub WaitForNoButtonsPushed
  Gosub WaitForButtonPushOrTimeout
  Gosub IndicatePushed
Loop
TurnLed1On:
  High LED1
  Return
TurnLed1Off:
  Low LED1
  Return
TurnLed2On:
  High LED2
  Return
TurnLed2Off:
  Low LED2
  Return
TurnLed3On:
  High LED3
  Return
TurnLed3Off:
  Low LED3
  Return
TurnAllLedsOff:
  Gosub TurnLed1Off
  Gosub TurnLed2Off
  Gosub TurnLed3Off
  Return
IndicatePushed:
  Pause 100
  Select Case buttonPush
    Case 1 : Gosub TurnLed1On
    Case 2 : Gosub TurnLed2On
    Case 3 : Gosub TurnLed3On
  End Select
  Return
WaitForNoButtonsPushed:
  Do : Loop While BUTTON1 Is PUSHED _
               Or BUTTON2 Is PUSHED _
               Or BUTTON3 Is PUSHED
  Return
WaitForButtonPushOrTimeout:
  buttonPush = NONE
  timeout = 0
  Do
    If BUTTON1 Is PUSHED Then : buttonPush = 1 : End If
    If BUTTON2 Is PUSHED Then : buttonPush = 2 : End If
    If BUTTON3 Is PUSHED Then : buttonPush = 3 : End If
    Pause 100
    timeout = timeout + 100
  Loop Until buttonPush <> NONE Or timeout >= TIMEOUT_MS
  Return
#43
Just thought i’d check how the switch on output 2 should be connected. The usual way of 10K resistor from output 2 (pin 5) to ground and then the normally open switch from the same pin 5 to supply? Or is it different because output 2 is not normally used as an input. Circuit drawing attached, cheers Dan FFB3C0B5-4D6E-4E1A-85F2-948808F2B921.jpeg FFB3C0B5-4D6E-4E1A-85F2-948808F2B921.jpeg FFB3C0B5-4D6E-4E1A-85F2-948808F2B921.jpeg FFB3C0B5-4D6E-4E1A-85F2-948808F2B921.jpeg FFB3C0B5-4D6E-4E1A-85F2-948808F2B921.jpeg FFB3C0B5-4D6E-4E1A-85F2-948808F2B921.jpeg
#44
Terrific RN you got it !!!!!! What the teacher does with the result is up to them. Thank you Thank you
Many double happy’s Dan 🤗😋👍
#45
Just thought i’d check how the switch on output 2 should be connected. The usual way of 10K resistor from output 2 (pin 5) to ground and then the normally open switch from the same pin 5 to supply? Or is it different because output 2 is not normally used as an input. Circuit drawing attached, cheers Dan View attachment 22839 View attachment 22839 View attachment 22839 View attachment 22839 View attachment 22839 View attachment 22839
Small error, the capacitor (100nf) from pin 1 does go to ground not supply, drawing error 😞
RNovember
Well-known member
#46
I think that your schematic wants to look like this:
  ^        Power     ^
resistor         ____|___
  |_____________|c.5  c.0|__LED_______
    |    _______|c.4  c.1|__LED____   |
    |   |   ____|c.3  c.2|__LED_   |  |
                                Ground
Then put some pullup resistors after the second line of Hippy's code like this: pullup %00000011
#47
#49
This is how I would wire things -
      |         .----.----.---.----------.---|--------------.-- V+
      |       _|O  _|O  _|O   |         _|_  |              |
      |      |_|  |_|  |_|    |   100nF -.-  |              |
      |        |O   |O   |O   |          |   |              |
SO <--'         |    |    |   |  .-__-.  |   |              |
          ___   |    |    |   `--|    |--{   |   ___        |
SI >--.--|___|--^----|----|------|    |--|---^--|___|--|<|--{
      |   22K        }----|------|    |--|------|___|--|<|--{
      |              |    }------|    |--|------|___|--|<|--'
     | |            | |  | |      08M2   |     3 x R + LED
     |_| 10K    10K |_|  |_| 10K         |
0V ---^--------------^----^--------------^--------------------- 0V
Note the LED anodes go to V+. This will make them active low; they will light when the output is set LOW, will be off when set HIGH.
This allows the wiring to the buttons, each of which will contain a LED, to be more easily done. Each will only need three wires ( V+, button signal, LED signal ) rather than four which would be the case if the LED cathodes went to 0V -
     |       _    |
     |     _|_|_  |
V+ --|--.--O   O--|--> Button input
     |  `---|>|---|--< LED output
AllyCat
#50
A "minimalist" solution needs only three PICaxe I/O pins and one resistor (if the LEDs are the same colour). ;)
Each grounded push-switch (i.e. Active Low) illuminates its respective LED directly, with the junction (LED cathode) connected to a PICaxe pin. The PICaxe pin (configured as an input) detects the Low level, switches off any other LED and pulls its own LED Low (so that it stays illuminated when the button is released). If all the LEDs are the same colour their anodes can be commoned and a single resistor from the supply rail feeds current to whichever is active. If the LEDs are different colours then separate series resistors would allow their brightness to be optimised/balanced.
#picaxe 08m2
pullup  %10110    ; Pull input pins High
  if pinc.1 = 0 then LED1on
  if pinc.2 = 0 then LED2on
  if pinc.4 = 0 then LED3on
LED1on:
  input c.2 , c.4 : Low c.1
LED2on:
  input c.1 : input c.4  : Low c.2
LED3on:
  input c.1 : input c.2 : Low c.4
The main problem is that the Simulator can't really handle this code. I'm not particularly surprised that it doesn't recognise the PULLUP command (so assumes the inputs are all Low). But even a PINSC = %10110 doesn't seem to fix it, so it's necessary to pause the simulation at the start and manually toggle the inputs to High. Even then, PE5 can't handle the simulation at all, but PE6 can be patched with a few extra lines of code, e.g. :
#picaxe 08m2
pullup  %10110
pinsc = %10110       ; Doesn't seem to work in simulator, so......
pause 10000            ; For Simulation, manually toggle the inputs to High (Yellow)
LED1on:
  pinsc = %10110            ; Only required for simulator patch
LED2on:
LED3on:
#51
      |        |O   |O   |O   |          |   |              |
     | |            | |  | |      08M2   |     3 x R + LED
     |       _    |
     |     _|_|_  |
Hi Hippy,
Ah the third switch should be connected to pin 2! now it works!!!! I assumed it went on pin 5, it’s the novice confusion of output numbers versus pin numbers. Thanks to all those that replied to my request, all very much appreciated. I’ll put it all into a box and get back to you with the result.
Cheers Desert Dan
