Good Evening All,
Probably a really basic question, but I'm not sure how you go about calculating a spec for a diode. I currently use an Imax B6 charger to charge two 6v 12Ah battery wired in series (12v).
At the moment I disconnect and take the batteries out and charge them, but I want to do it in situ. I plan to do this via a DC plug type connector, but I want to prevent flow from the battery to the female connect when not charging. What type of diode would I need?
Also, is there a simple circuit or device that would automatically swith power to the circuitry off while charging, and back on when not charging?
Many thanks
Russ
Many thanks
Russ
