I have a Digole graphics LCD driver and I am driving it using its serial input and it works great, I just want to change the start up screen.
I have used the software that they provide on the website to convert the image but I do not understand the manual.
I have the data I want to send in hex format for an image 128x64 I just don't understand the lower byte of data length higher byte of data length and could do with some data lessons if possible.
Set Start Screen, 1st B is the lower byte of data length,
2nd B is the higher byte of data length, following by
data.
For mono display, the start screen is bitmap data;
For color display, the start screen is commands set, the
first and second bytes are the commands length.
http://www.digole.com/images/file/Tech_Data/Digole_Serial_Display_Adapter-Manual.pdf
page 7
Thank you
Rich
data.
page 7
Thank you
Rich
