Dice board
hornshawr
I am using PIC Logicator 2005 and for some readson cannot download the programme I have designed. Programme runs fine under simulation but as soon as I try and download I get the error message "Illegal character XXX". Has anyone got a programme to press the switch on the Dice board to get the LEDs flashing....then another press of the switch to randomly select a number on the dice. I know I am probably doing something silly but I have been trying for a while now.:mad:
You have probably used an illegal character within a name (e.g. a procedure title). Check that you haves only used a-z,0-9, it is not starting with a number and not containing spaces. The current version (3.2.7) has better error checking on this front than your out of date version.
