procfanousek
Maybe it comes handy for someone.
There is an interesting board with 08M2 onboard that can be inserted into the breadboard. You can see it here: http://www.mo-na-ko.net/php/portal/viewtopic.php?id=3200
I use it myself together with breadboard and I like it very much. The advantage is that all pins are available in the breadboard and on the board itself as well. It is very useful when connecting servos because a servo is fed at the same time. I can post source files for Eagle PCB editor and circuit diagram if there is an interest. The board, therefore, can be inserted into the breadboard, used separately or used as a programmer. There is also version for 18M2 including source files.
