uC prototyping blocks, aka "Dev Blocks." These are small single component boards that are ready to plug into a breadboard. Nothing special, but a real time saver. I have them standardized so that the picaxe pin always connects to the leftmost terminal, then ground. The rightmost is for V+ or a second picaxe pin, depending on application.
The bi-color LEDs are nice space savers, they're actually three colors, since if you power both anodes, you can get amber out of it.
The connectors are interlocked in the first picture. The blocks are, from left to right:
Piezo element
Bi-color LED (red/green) x2
SPST, N-O momentary switch w/ pulldown resistor
Light dependent resistor (LDR)
DS18B20 I2C digital temperature sensor
LM35 temperature sensor (10mV/C)
Here the connectors are in a more natural state:
Piezo element
