Debugger Error: "TRISC Simulation Error"
c00kie
I get the above in the error log when I simulate my design. The circuit is based on a 14M chip. Does this indicate a software problem or is it likely to be an error in my schematic? I should point out that I'm very much a novice and have only just purchased the VSM software. However, this is a design which I have already built and it works OK as a real circuit. I have also successfully simulated a design based on an 08M chip.
Cheers,
Mark
c00kie
Well, it seems to be the code that is the problem, as I wrote some simple code which worked. I'm attaching my basic program in the hope that someone can help. Probably not the greatest code but it does work in the real world, just not in VSM. :(
Cheers,
Mark
