Describe how the chip is powered. That's a common cause of problems.Hi,
I had a few checksum errors to a 20x2 (using a AXE118). I only have power and serial download cable attached and it won't program at all anymore. Anyone have any magic tricks to recover from this?
Thanks
Jason
That is a great assumptionIt's either dead or not...
Hmm not sure that makes much sense (to me at least).Then it would start programming half way and error.
Yeah, what he saidI don't think he means that Westy.
I think he means that it began to behave as though it programmed partially then erred.
i.e. the actual behaviour of partial programming started.
Well, nothing is impossible huh? Reason unknown. Ah well, that's life.
It may be worth reviewing and checking your circuit and wiring. This is similar behaviour to when I destroyed an 18X having connected an output pin to a pot wiper put in the wrong place. Download was working fine and then progressively got worse.It was working fine. I had it hooked up to a ethernet to serial module and it seemed happy enough. Then it would start programming half way and error. This became more and more frequent until it completely refused.
And i thought only fools like myself done those sorts of things.I destroyed an 18X having connected an output pin to a pot wiper put in the wrong place.
