toxicmouse
I have a small model boat that is powered by a speed 400 dc motor rated at 7,2V. the motor turns a propellor through a gearbox. the power supply is 6X 1,2V NiMH batteries connected by a relay only.
the problem is that the boat needs to move a bit faster. i dont have easy access to larger motors, but i do have a few more speed 400 motors.
there are obviously a few combinations that i can put together, but to save me on building gearboxes i was hoping a kind soul would impart some wisdom on a good solution.
i am thinking of adding another motor, joining the drive shafts and sending that through one gearbox. also attach them to the same power source. i think that this will increase the torque, meaning the prop should run faster- if too fast then it is easy to put on a larger prop. is this logical, or is it better to add a separate power source to each motor? or is it better to keep the one motor and add the two power sources in parallel to reduce the internal resistances?
many thanks
many thanks
