Thanks for the last reply under post topic_id=2449&forum_id=15
I've installed the software on a different Pentium III PC, this time with 256MB of memory (most of it showing as free). I get exactly the same type of error, suggesting that the problem is probably not related to odd PC configurations or a simple lack of memory.
A screenshot of the failure is available at http://www.tonygraham.co.uk/picaxe_failure.gif . (It is showing 4 sensors - relative humidity and temperature as address, RH1, T1, RH2, T2)
Alternatively, I've been thinking about your suggestion of downloading in bits: Is the PC-side source code for the datalink available? I would like to be able to modify it, either within your softare or within Visual Basic, so all data can be downloaded properly in one go. (Downloading in pieces using the datalink utility is not really any good to me).
....also, just noticed by using the serial terminal that the datalogger is still sending 'somthing' after the datalink hangs. I've shown the output at http://www.tonygraham.co.uk/picaxe_terminal.gif . Does this give any clues?
Thanks again, Tony
Edited by - TGraham on 3/30/2005 4:24:17 PM
Edited by - TGraham on 3/30/2005 4:27:28 PM
Edited by - TGraham on 3/30/2005 4:34:38 PM
Edited by - TGraham on 3/30/2005 4:47:34 PM
Thanks again, Tony
