1 Penny (from 1968 - 1991) 20.32 mm diameter, 1.52 mm thick, weigh 3.56 grams and are made from 97% copper, 2.5% zinc and 0.5% tin. The edge is plain.
1 Penny (from 1992) 20.32 mm diameter, 1.65 mm thick, weigh 3.56 grams and are made from copper plated steel. The edge is plain.
2 Pence (from 1971 - 1991) 25.9 mm diameter, 1.85 mm thick, weigh 7.12 grams and are made from 97% copper, 2.5% zinc and 0.5% tin. The edge is plain.
2 Pence (from 1992) 25.9 mm diameter, 2.03 mm thick, weigh 7.12 grams and are made from copper plated steel. The edge is plain.
5 Pence (from 1990) 18 mm diameter, 1.7 mm thick, weigh 3.25 grams and are made from 75% copper and 25% nickel. The edge is milled.
10 Pence (from 1992) 24.5 mm diameter, 1.85 mm thick, weigh 6.5 grams and are made from 75% copper and 25% nickel. The edge is milled.
20 Pence (from 1982) 21.4 mm diameter, 1.7 mm thick, weigh 5 grams and are made from 84% copper and 16% nickel, and are seven sided. The edge is plain.
25 Pence (from 1972 - 1981) 38.61 mm diameter, 2.5 mm thick, weigh 28.28 grams and are made from 75% copper and 25% nickel. The edge is milled. During their period of issue, they were referred to as a Crown due to them being of the same dimensions as the pre-decimal Crown coin. These coins were discontinued from 1982 but remain legal tender. Circulation of these coins is uncommon.
50 Pence (from 1997) 27.3 mm diameter, 1.78 mm thick, weigh 8 grams and are made from 75% copper and 25% nickel, and are seven sided. The edge is plain.
1 Pound (from 1983) 22.5 mm diameter, 3.15 mm thick, weigh 9.5 grams and are made from 70% copper, 24.5% zinc and 5.5% nickel. The edge is milled with incuse lettering or ornamentation.
2 Pound (from 1986 -1996) 28.4 mm diameter, 3.1 mm thick, weigh 15.98 grams and are made from 70% copper, 24.5% zinc and 5.5% nickel. The edge is milled with incuse lettering. Circulation of these coins is uncommon.
2 Pound (from 1997) 28.4 mm diameter, 2.5 mm thick, weigh 12 grams and are bimetal made from 76% copper, 20% zinc and 4% nickel in the outer ring, and the centre is 25% nickel and 75% copper. The edge is milled with incuse lettering.
5 Pound (from 1990) 38.61 mm diameter, 2.89 mm thick, weigh 28.28 grams and are made from 75% copper and 25% nickel. The edge is milled. Intended as a souvenir or collectible, but occasionally seen in circulation. These coins are now referred to as a Crown due to them being of the same dimensions as the pre-decimal Crown coin.
