Sadly, i don't have any access to a Scope but when i measure the freq generated by the RTC with my digital multimeter it nicely say's 4.096 Khz and after dividing it by 100 using the 4059 it also says 40.96 hz so i don't think there are any accuracy problems with the RTC clock.
After reading Hippy's post it confirmed my idea that the accuray problem is caused by rounding up the fractal numbers of a pulsin measurement.
My plan is to let the 28X drive the 4059 divider to automatic raise the divide factor after the pulsin result is less than a certain value. (the lower the freq. the higher the accuray) and to make some routines to make it posible to do some fractal calculations for calclating and displaying the freq. (using // to get the remainder value and repeat the calucation on this value multiplied by 10)
And A PLL driven by a VCO, ehhr i know about the meanings of these words and i know about what these components do but for me this is more advanced stuff and i'm a programmer with a minimal electronics background so this is a littlebit to complex for me (for now).
I Also thought about overclocking the PICAXE to get a finer resolution, for this i need a 8 or 16 Mhz oscilator which i have to order online at thechsuplies (i can't find these things in the netherlands, maybe some dutch reader can give me some info on this) and due to the shipping costs i have to order more stuff. maybe next month
I'll try some idea's you all gave and will post the results back !
Just as my previous project, there are many already build freq counters, my multimeter even has a simple one and this thing was much cheaper than all the time and components i've spent on this project but i want to see if it's posible and try to overcome some limitations on the picaxe. I know there are faster PICs which can be more accurate but for me it's the game of doing something difficult which makes it fun ! (and not to forget the learning aspect).
O, BTW beanybots posted something about the duty cycle generated from the 4059. For this reason i use a flipflop as a divide by two, this way i have a nice 50% duty cycle.
