Hi, if I download a simple PIC Logicator program to a T4 board that is supposed to turn on a motor and buzzer, how do I connect the OUTPUTS and set the board up to run these when a switch is pressed?
I will try and use the datasheet, but I am no expert as you will have guessed. I did mean to physically connect and electrically enable them when a downloaded logicator program is used on the training board.
Thanks for the reply, I could do with a dummies guide to using the board!
