Thanks Hippy
I am a newbie to this. So if you were looking for a microproc. that you wanted to use purely for short burst 'clever' sound using a piezo(over 100Db). Maybe also a basic LED to show battery life(on/off) What spec chip would you look at?
I need something that is cost effective and readily available.
Almost any micro which runs at a decent speed should do the job although you haven't specified exactly what sort of sound you want. SID, SoundGin and most other sound generators can generate sound that's acceptable for audio ( ie Musical ) use. Not sure what you'll get ( or conversely need ) if you are driving a 100dB piezo ! Piezo's are probably best driven by a square wave signal than an audio waveform I'd have thought.
This desired "clever sound" is a little enigmatic in terms of definition and it may be possible to generate something usable with a PICAXE using the SOUND commands. You're really asking us to solve a problem when you haven't said exactly what the solution needs to be.
SoundGin is just a programmed 18F1320 and anyone can write their own sound generating software if they put their mind to it. The cost mark-up covers the effort of the SoundGin programmers in providing a ready-to-go solution. You're paying not just for the chip and the time the programmers put in, but also a comprehensive PC-based test/control program, documentation, shipping and manufacturing costs and support.
If someone wants to develop their own sound generator as a project, and has a fairly relaxed timescale, a low-cost do it yourself approach is fine, but if they consider their time worth $10 an hour, they have just 2.5 hours to finish the project. If it's going to take longer then the SoundGin is more cost effective, and readily available.
I think the best way to get round any confusion and get your project up and running as fast as possible is to define exactly what this "clever sound" is. It's easier then for people to suggest what you will likely need rather than what may do what you need.
You can also start developing your project using what the PICAXE does support ( eg SOUND ) and worry about the final sound as a separate sub-project.
