I have found that some commands, for instance ReadTemp cause delays in the execution of commands in other starts whilst to data from the sensor is read (up to 750mS). In my case this causes sluggish or unread button presses in the real hardware. The program also misses Time compare functions which have a 1 second window. I suspect that other I/O serial functions will have problems the way I have written the flowsheet.
Can anyone tell me which commands (ie. LCD, Wait, InfraIn, InfraOut) cause delay problems and what the delay may be for subsequent commands in the same start and others that are running in parallel? Are there ways to minimise these issues in Logicator and still have a responsive user interface?
Thank you
Thank you
